Johnson pump bilge pump alarm?
bensmiata
Just noticed this hiding on the console, what is the location of this alarm in the bilge for a 2019 R-29? Thanks!
On our 2020 C28, it is tied to the forward bilge pump.
Confirming on the R29S we had, it was on the forward bilge pump.
Jim
Yes, it a high water alarm.....so it is wired to the FWD bilge pump since it is mounted a little higher in the bilge.
Rocky
Hi all,
The high bilge alarm is not wired to the fwd bilge pump, but yes it does sit in close proximity to it. You will notice there are two circles molded into the side of the alarm sensor. You can test the sensor by placing the alarm in the "armed" mode and placing one fingertip in each of the circles until you hear the shrill beep at the panel. Hope this helps.
Cheers,
Ralf
Ralf H":3ts8fvw1 said:
Hi all,
Cheers,
Ralf
Thank you! Very helpful!
