Rocky Lou
- Aug 2, 2019
- C-302 C
- Sea Suite
I thought I'd seen everything with the inverter but have a new issue. The inverter will not reset using the GFI reset buttons. I do not have AC panel 1, however, I have AC panel 2 working and the inverter is charging my batteries. There are no Fault codes showing on the inverter screen. I have two green lights for power going into the AC panel however, as mentioned, the VU meter on AC main 1 reads zero. Fuses seem to be OK and hopefully someone has seen this before.
