Lewmar winch relay/solenoid location?
Remedy2
R-21 EC
Southern Resident
2022 C288. Windlass goes up but not down. No “click” when activated from the helm or the bow toe button. Assuming winch is fine as it operates fine in one direction. Suspect a relay and/or solenoid. Can you please tell me where that is located?
TIA!
Correction goes DOWN not up.
Hi there,
The solenoid is located in the electrical cabinet over the toilet in the head. It should be relatively easy to locate. It's a black box with several large positive and negative (read: red and yellow) cables going to it and it will have a small red lever on it to reset the unit. If the little elver is popped out at a 45degree angle, you know that this is the problem. Hope this helps but please let us know.
Cheers
Ralf
Thank you!! Will be on the boat Friday and reset it. Appreciate you.
