Livewell setup in 2021 R27OB
Josh
I want to set up the livewell to keep bait alive.
1. Where can I obtain a threaded overflow pipe to fit in the female threaded drain hole? (It looks like a 1.25 inch drain hole.)
2. What's the best option for supplying seawater to the livewell? One option is to run the raw water washdown hose over to the livewell, but not sure if this will work. Is it ok to run the raw water pump continuously for several hours?
Thank you.
