Locating turbo charger
jjbussell
C-248 C
FMLT2593C808
FILE SIX
I have a 2008 R25 and my turbo went bad. I have not been able to locate a replacement. The engine is a cummins QSD 2.0L, 150 HP. The part # on the turbo is 35242129F. Has anyone else had this problem and found a solution?
File Six
Crowley Marine on line. Try the link below. It shows in stock. Make sure the serial number on your engine matches. If not there is another page.
https://www.crowleymarine.com/parts/317567.cfm
And SLOW DOWN. These small diesels are only rated to run continuously at 80 percent power. On the QSD the turbo appears to be the first point of failure.
Thank you for the information. Just purchased the last one they had.
File Six
