danester
- Mar 14, 2018
- R-21
- SEASCAPES
Hello! I have a 2016 C26LE- and I having a Fusion MS504 amp and a Fusion 10in Subwoofer (400W) installed professionally as an addition to the Fusion stereo head installed by the factory..
I'm looking for advice on where to install the "in wall mount" subwoofer- it is pretty big (10in diameter). The only area I can see install is located onto the fiberglass wall, when stepping down into the Vberth- to the left- just under the TV and just above the seating area. The opposite side of the wall has the fiberglass molded steps. Is there any issue cutting a hole there, and what things are behind that wall, under the steps? I appears the subwoofer would extend appx 6-8 inches into the hole cutout...Thanks in advance- Dana
