acdfpic
- Dec 28, 2018
- C-26
- FMLR2525B414
- Destined Nomad
I’m on the Great Loop and two weeks ago, I lost my transmission while traveling between Alpena and Cheboygan, Michigan. I was cruising along at about 2500 rpm and felt a “stumble.” I pulled the engine back to idle and tried to assess what the issue was. I had no propulsion in forward or reverse. I was dead in the water. I called for a tow, which I have detailed in a Facebook posting in the TugNuts group, so I won’t go into it here. I was towed into a port with no maintenance facilities, and was not able to make contact with a mobile service person. They didn’t even call me back. I arranged to get towed to a marina in Cheboygan.
When the transmission oil filter was removed, there were obvious chunks of metal and shaking the filter sounded like a child’s rattle. Not a sound you ever want to hear. The parts guy at the marina contacts Volvo to find a replacement and there is only one available anywhere in the Volvo system, and it’s in Sweden…and it’s $10,400!!! Total cost for the repair was just shy of $12,000. For me, that was a trip ending amount. I would have to load the boat on the trailer and head home to the PNW.
It was up to me to find a replacement. Of course, the internet was the first stop with none showing up anywhere. I then tried finding a rebuild shop….4 to 5 months.
I remember reading on TugNuts that the Volvo box is made by ZF, and luckily the first ZF dealer I talked to was extremely knowledgably about ZF and Volvos. It turns out that the Volvo D3 transmission HS45A EC is a ZF 45A EC and unless you have a trolling valve, it’s a direct replacement. Unfortunately, the only one available right then was in Everett, WA and while we were trying to figure out the details, it was sold. The cost of the ZF, shipped to Michigan was going to be $3200. Quite a difference from the Volvo.
I had tried to make contact with RT at the beginning of this, and got a call back from Kenny Marrs. He went out to their storage container and happened to find a transmission left over from when they changed the engines in the last few 25SCs to 170 hp. I got it shipped to me and installed on Friday. It took the technician about 45 minutes to remove the old one, and about an hour and a half to prep and install the new one. When we went to start, we discovered that the engine was hydrolocked. We got that fixed and she runs fine, but I will discuss that in another thread.
The boat has less than 800 hours on it and has been regularly serviced, in fact less than 20 hours before this. I bought the boat with about 300 hours on it, so I don’t know of any previous damage, but there hasn’t been any since I’ve owned it. The solenoids were replaced with the new style 300 hours ago. We won’t know exactly what happened until I get it rebuilt sometime this next winter.
I hope you never have to go through this, but if you need a new transmission, I would recommend giving Mike Vogt, at Harbor Marine in Everett, WA a call.
Chris Boyd
2014 RT 25SC
Destined Nomad
Facebook Group: Destined Nomad
Chris Boyd
2014 RT 25SC
Destined Nomad
