S. Todd
- Jan 27, 2015
- R-29 S
- FMLT2916J021
- Non-Fluid Motion Model
- Innova & Paddle North kayaks
- Audrey Rose
Our 2015 R25SC has been sitting in its temperature controlled garage for about 5 weeks since we came home from the lake, except for last Saturday when it came out the door to get washed and dried and returned to its parking spot. I have a dedicated 30 amp outlet in the garage to plug the shore power cord into to keep the batteries charged. I typically run the charger for about 1 week per month. It has worked fine until tonight when I went out turn on the power to that 30 amp circuit. No operational battery charger, no power to the main AC panel by the helm. 🙁 The Blue Seas main 30 amp circuit breaker located in the port side cockpit locker had blown. I reset the breaker and within 3 seconds it blows again. I turned off the battery charger and the main breaker up by the helm (everything else has been off since we left the lake where and when everything was working fine). I reset the main breaker in the cockpit locker and turned the power back on to the shore power cord. Within 5 seconds the Blue Seas Main breaker blows again. I am baffled. :?: Has the Blue Seas 30 amp breaker failed and does it need to be replaced? (It is conceivable it failed 2 weeks ago the last time the charger was running, but if so I was unaware of it until now.) If it is not a bad breaker, does that mean a have a short somewhere between it and the main panel? If the short is not there, why else would it trip when the breaker coming into the main panel by the helm is off and all the switches there are off? Is there any way to test the breaker without buying a new one and replacing it? Has anyone else experienced a failure of this breaker? I intend to change oil tomorrow and trust everything else will perform properly.
Todd
Todd
