b1itsjustme
- Oct 16, 2014
- C-24 C
- Non-Fluid Motion Model
- Cutwater 26
- Somnium
Hi.
I have an issue with my Generator lugging down and dying. In speaking with Sergio of Mase NA in Miami he explained that the genset has a 2 micron fuel screen attached to the bottom of the fuel pump inside the sound shield. Since the Racor primary filter for the generator has been replaced and is clean, this seems the likely culprit. OK, I get that, now.... how do I get to it?
My boat is a 2014 Cutwater 26. I bought it new in Tampa two years ago. I use it, a lot. The Volvo has 780 hours on it and the Mase has 460 hours.
It is ridiculously tight in the front of the Genset. I can't even fit my arm down between the forward edge and the sound shielding. I think that it would actually be easier to by-pass the old pump and install a new one on a bulkhead. However, sooner or later that raw water pump belt is going to need a replacement and I'm going to have to get in there. Short of pulling the whole unit, what can you suggest?
Bruce
Bruce
