BB marine
- Feb 1, 2016
- C-26
- Non-Fluid Motion Model
- Grady White 208
- PORT-A-GEE
I agree with that about statistics. In my work we call it bean counting and the beans never add up ! I'm looking for real numbers . The factory numbers are off a bit , one could argue salt water to fresh water , test runs done in perfect conditions, and maybe a little human factor added in . I agree each boat is going to run different , load distribution , how much gear , weather conditions , and bottom condition . I have a couple years to figure it out . Each trip we take I clear the trip on the Garmin write down beginning hours , remaining fuel , ( a must because of inaccurate fuel gauge ) date and time and weather conditions and go . I will switch back and forth from Navigation on plotter to fuel on the garmin and find the best rpm/Gph/mph then switch the Volvo gauge to engine and monitor temp / boost/ and run . When I fill up the tank I reset the fuel tank on Garmin and then do calculations on fuel economy . I base on miles per gal and hours per gal . I did a 100mile trip last week average running speed 3220 rpm, average 12kt , average 14 mph , average 2 mpg , 7 Gph , burned 49.4 gal fuel , my garmin was off by 1/2 gal on fuel left in the tank . Weather conditions 75 degrees , waves half the trip 1 to 2' then increased 3'to 4' . At 2200 rpm I'm at 7kt , 3mpg , 2.6 Gph . Anything slower then that the numbers come in with great economy . Anything above the 2200 rpm I might as well throw the throttle down it doesn't change much just get there faster and put less hours on the engine . As far as the Cutwaters being faster , I think the 28 is much faster then the tugs , but the 26 runs about the same. The extra 2 feet with that hull design helps the boat to level out a little more . It has just 40 hp more and is a good 5kt faster . I really like my 26 Cutwater just a little disappointed in the performance . Hopefully with some more running time , and more information from experienced Cutwater/Ranger owners ( Tugnuts ) I'll get it dialed in .
