barling
- Aug 9, 2019
- C-302 C
- Non-Fluid Motion Model
- Bristol 29.9
- Barling
My 2014 Ranger 31S has the above stated Generator. I know its engine is a 2 cylinder, 4 stroke, water-cooled 2900 RPM Kubota block diesel, which has a great reputation, but I really know nothing more. To date it shows it has run 9 hours. It's ratings are 5 kWe, 5 kVa, a Phase 1, Voltage 120, 41.7 Amps, which tells again doesn't tell me whether it is an efficient as a battery charger. I know it is best for the engine to run under a 1/4 to 3/4 load and that the generator will shut down or its line circuit breaker will trip if the sum of the loads exceeds the generator set power rating. What is its set power rating? The manual has a table which sets forth the typical appliance loads. I would like to know how efficient is it as a battery charger? How many phases does it go through when charging? How long will it take to recharge the four house AGM batteries? How do I know the engine is under a 1/4 to 3/4 load when I want to recharge the house batteries? How is it beneficial to my enjoyment of the boat while I'm on the hook. I don't think I'm want to start the generator when I want to use the microwave or the electric stove? Where might I find a good discussion about the usability of my generator?
