greeninbetween
- Jun 5, 2016
- C-24 C SE
- FMLP2118J112
- Non-Fluid Motion Model
- 1951 Simmons Sea Skiff
- SisterShip & Rebecca Ann
On my 2012 R21-EC with the Yanmar, there is a bulkhead in the engine compartment between the battery bank and the engine. There are various electrical components mounted on it, the coolant overflow tank, and the rubber exhaust hose passes through the bulkhead. I recently noticed that the bulkhead, which appears to be made of a plastic-like material (Star board?), has distorted considerably. My engine is not overheating and the two engine box vents are clear. Has anyone experienced this on their Tug, and what did you do to correct the situation? Any suggestions for a more durable and heat resistant replacement material? I am almost considering some ducted fresh air into the compartment to drop the temperature down a bit.
