Brian B
- Apr 19, 2012
- C-26
- FMLR2512L910
- Non-Fluid Motion Model
- Sold in 2021
- GANSETT RANGER (2010) Yanmar 4BY2-150
2010 25SC, just over 1000 hours.
I was missing a bolt head on one of the bolts that holds the skid plate to the keel forward of the prop. The boat is on stands for a bottom paint job so I thought it would be a good time to address the issue. There are 7 bolts that hold the plate on. In removing the bolts 3 bolt heads separated from their studs as I began to turn the socket wrench. I was able to remove the plate then I was able remove all the threaded studs with a vice grip except for one, the metal just crumbled even with the keel. These are 3/8 -16 bolts. 6 are 1 5/8" L and 1 is 3 1/4" L.
I went to W.M. for new bolts but no one seems to know what grade S.S. they sell.
The old bolt heads are marked S30400. From the web: UNS S30400. 304 Stainless Steel Bolts are austenitic stainless steel bolts manufactured from alloy containing chromium and nickel. Stainless Steel 304 Bolts are used for corrosive environments.
Should I be replacing these bolts with 316 Stainless?
