Subject: Moving from forward to reverse on R-21EC
I've noted that moving the throttle lever from forward to reverse too quickly results in some unwanted clunking sounds. Reading the engine operations manual I see the correct way to do this is to allow the throttle lever to rest in neutral for a brief moment to allow idle RPM to be reached before continuing the movement to reverse.
Do others find this to be the proper method to avoid the clunking sound, or is there some other preferred method ?
There are times when I want to 'kill' the boat's forward momentum and this necessitates moving the lever into reverse quite quickly at times. On my R-25 I would do this without there being any requirement to 'rest' in neutral.
