My first single handed boat launch
baz
Subject: My first single handed boat launch
I launched my R-21EC for the first time at a boat launch ramp a few days ago. Apart from lining the boat up to the dock several times and ensuring my Volvo's rear wheels did not go over the edge of the corrugated ramp's ledge all went well. Rather than climbing down from the bow I decided to get my feet/legs wet to make the final release from the trailer.
The length of the EZ-Loader meant the R-21EC floated well before my rear wheels were immersed in the water and my dual exhaust pipes not being completely submerged. 😀
CONGRATULATIONS on your first ( hopefully of many) launch. I've been there and know the anxiety you experienced and now you can join the club. Your embroidered launch badge will arrive via USPS soon. Hopefully retrieval was just as successful.
Cheers!
Capt'nKarl and Sara on the hook
The nice thing about the R-21EC is that it floats quickly from the trailer. So there's no pushing involved nor aggressive car motion required to get her off the trailer. It was really quite easy.
I await for my 'launch badge'.... and can I get it next day expedited delivery without requiring my signature. :lol:
Nice job Barry. I thought I was the only person who rolled up his pant legs while launching! A pair of old slip-on aqua socks helps a great deal while launching, keeps your feet safe and helps to keep one from slipping on a slippery ramp. Hope you had a great day for a cruise.
Jim
Feels good after launching,wish you many more. Met a husband and wife at our seasonal slip this past season,both suffered slip and falls resulting in broken ankle and leg. One on slippery ramp the other getting on boat.I also Was in a hurry one day and fell into the boat,wet gunnel and moving to fast no major injurys,only posting because seeing ramp in photo made me think of slippery conditions.
Yes, it was slippery and I took great care moving my feet slowly to make sure I had a good grip on the ramp. I have stuck rubber non-slip pads on the trailer I-beams as the bare I-beam can be very slippery when water sits on its upper surface. I probably need to add a couple more on the tongue end as well. Releasing the winch strap was a PITA as I fumbled with its release knob which refused being rotated at first.... all part of being the first time doing this boat launch I suppose. I'll get better at this operation with time.
My only concern is that the boat launching technique is likely to be different for each boat ramp as ramps can vary; some with steeper or shallower ramps, some smooth and some corrugated (as this one was), dirt and gravel, some with floating docks that rock/wiggle about, etc.
Con grats on your new freedom 🙂
I'm sure this is not news , but just in case ... make sure you rinse off the trailer with fresh water after dunking it in salt water. Helps it last longer . I make sure all the tire area and brakes get a good rinse.
Understood. In this case the water was fresh so I did not need to wash down with fresh.
There's one issue I'm trying to get straight in my head. This is the fact that the EZ-Loader trailer has hydraulic surge disc braking. In the EZ-Loader manual there's some wording about disengaging this feature when launching the boat on a ramp.
What is the bottom line advice about this ?
There should be a pin you can put into the mechanism that prevents the brakes from engaging when you back up. The way the brakes work are when you are driving and brake, the force of the trailer pushing against the hitch applies brakes. Harder stop more brake pressure. If you were trying to back up and there is a grade or the trailer does not roll easy ( gravel ) It may apply trailer brake pressure, making it even harder to back up. Just remember to remove the pin when you have the boat loaded and are driving forward.
Hello Barry,
If you have a 5-pin connector to your tow vehicle, the 5th pin powers a solenoid which deactivates the surge brakes whlst backing up. Now backing DOWN a ramp - you have NO BRAKES with normal surge brakes anyway - solenoid or not. This is trivial with a lightweight rig like the 21EC, but can become an issue with the heavier tugs. Electric over hydraulic (i.e., "surge") brakes eliminate this as they WILL work wilst backing down an incline.
When launching, sometimes getting your feet wet is unavoidable. I generally try to avoid this. When its summer time and the water temp is comfortable it's not a big deal. When its COLD - it's a big deal. As the others mention above, FALLING is a serious hazard when you walk in the slime area of the ramp. Keeping your feet out of the water begins by not backing too far into the water. I try to keep my tow vehicle's rear wheels out of the water. I know the trailer manual/dvd shows the safest way to launch your boat is by backing it fully into the water before releasing the winch strap and safety chain....BUT, once you gain some experience, and understand the risks, you will find it is normally fine to back the boat into the water (say, about HALF WAY) but so there is plenty of dry ramp to allow you to walk behind your car and unhook the winch strap without getting your feet wet. Then, back in until you see the aft end of the boat start to float. You are backing in SLOWLY but come to a quick stop when the aft floats. Next you will see your tug slowly slide off the trailer...and you have not dunked the rear of your tow vehicle into the water, nor walked on the slimy portion of the ramp thus subjecting your self to a fall type of injury.
When I'm solo, I tie a 20' line to the bow cleat and secure the bitter end to my truck. After she slide off the trailer, I calmly walk to the finger dock with the line from my truck in my hand, and secure the boat, then park the truck. In those cases when you must back in too far (rear wheels in the water), then use your boat hook to grab the line whilst standing on the finger dock, secure the boat, and release the line to the tow vehicle from the bow cleat. For me, the finger dock is a BIG HELP. I've never understood why some boaters will back into the CENTER of the double slot between two finger docks, thus taking up two spots, while loading (invariably with POWER) back onto their trailer. This practice seems inconsiderate when they could do the same thing next to the finger dock and still leave a full boat-width slot next to them for the next guy.
As you said, some boat ramps will require different practices, but, in general, my advise is to strive to keep your feet dry. That won't always be possible, but if you have developed a technique, then you can use it or modify it as needed. The more times you walk into the slimy portion of the ramp, the odds of falling will eventually catch up.
And the trailer tongue...yes it gets slippery. I've installed lengths of 2 x 10 painted with a non-skid additive so I can safely "walk the plank" without risk (or, LESS risk, really). I find this VERY helpful when loading the boat by myself, I can simply take the bow line back to the trailer, then pull the boat onto the trailer as far as she'll come whilst floating, then easily secure the winch strap to the bow eye all while standing on the 2 x 10s. Easy peasy.
You will learn more each time you launch, and probably get better. Sometime simply dilly-dallying at the ramp after you've moved your boat away from the action will let you SEE what to do next time (or NOT to do) just from watching others. 😱
dave
When I bought my first boat years ago,a 19ft Montauk whaler. Guy that I purchased it from was a good guy ,took me out to practice docking ect. He told me always be careful with winch handle,somehow when he was younger ,it was under a lot of strain,somehow it spun and broke his teeth and maybe his jaw I forget. I always think of that each time its under a lot of strain cranking it. Im not a safety instructor,just things coming to mind.
