portlandtug25
- Jun 17, 2014
- C-26
- Regalo
Hello Factory Folks,
While it has been a good boat with few issues( I bought it new) a problem seems to have developed with my 2015 R 25 (Volvo D3, 450 hours) that is becoming very frustrating.
At any RPM between approximately 1300 and1700, there is a high pitched resonation that fills the cabin. The sound is not like a gear whine that changes pitch with RPM, but rather a continuous high pitch sound that is somewhere between a whistle and a ringing, ( maybe two octaves above middle C, for the musically inclined). It first appears at 1300 RPM, stays at the same pitch until 1700, at which point it fades away. The sound wavers a bit in volume through this RPM range and at times seems variable depending on current direction and/ or rudder angle, though this effect is very slight, and inconsistent. ( I'm on the Columbia River). Again the pitch does not change between those two engine speeds, only slight variation in the volume of the noise.
The upshot is that I can run at 1290 (One gal./hour) with very quiet operation or above 1700 (2 gals./hour) with normal noise level, but anything in between is very unpleasant. The effect seems to be worsening with time. When I first got the boat I found 1300 to 1600 RPM to be a useful range, in terms of speed, fuel consumption and noise level--low noise level being one of the things I appreciate about the RT.
I have maintained the boat to factory specs (as per owners manual) since new utilizing the local Volvo dealership.The boat runs and handles perfectly otherwise.
I would appreciate any help you can offer.
Roger Friedel
Roger Friedel
