Cutter 30124
- Sep 15, 2023
- C-30 CB
- Potomitan
The best way to tell is to look at the tags on the wires. Also, the four house batteries are obvious because they are connected together with short wires between them. Check the tags to the other two to be sure though.
If you need to identify the battery by a cable run, the best cable to check for me was the one that goes from the battery bank to the stern thruster. Then, you can check the schematic that came with your boat to identify which battery goes with the stern thruster.
I got six Duracell AGM for the great loop, and they've been good. 5000 miles, 1000 engine hours on them. Never a problem with the thrusters when we've needed them, or the starter.
Good luck.
If I may ask, can you please elaborate on which particular Duracell AGMs you used? Looking to replace 4 house batteries 2019 30CB. Lots here seem to prefer the Lifelines. Pretty sure mine are original Universal AGM. Also, which boat do you have, and do you run a generator?
Thanks!
