Need serial numbers for Garmin 5212 and GHP 10 AutoPilot
baz
My Garmin GHP 10 Autopilot System instructions provide space for recording all the serial numbers for its components as listed below
1. The Course Computer Unit (CCU) (Garmin part # 010-11052-00)
2. The Electronic Control Unit (ECU) (Garmin part # 010-11053-00)
3. The Hydraulic Pump (and motor; either 1.2L/2.0L or 2.1L)
4. The Shadow Drive (Garmin part # 010-11054-00)
5. The GHC 10 (Garmin part # 010-00688-00)
In addition to the Autopilot GHP 10 I need to obtain the Serial number for my Garmin GPSMAP 5212 ChartPlotter.
How do I obtain these numbers?
Thanks.... 🙂
The serial numbers on all of the Garmin units I've owned have been on the back of the units. Your 5212 is console mounted and I'm not sure how to you might access it.
Gene
On the back of the unit you can view from inside the helm dash. Access inside the V-berth. Located on the bottom portion of the back of the chartplotter.
Thanks Andrew. Will look there to find the SN. 🙂
Andrew:
The Garmin display unit does not have SN anywhere I can see on lower back.
See picture below that I took.
ekp723
I was able to get the SN for the GHC 10 (see picture below I painstakingly took to obtain this as I could not read the SN with my naked eye)
qi7gny
One further question... The car-like circuit breakers on the backside of the drop down hatch lid shows a Fuse marked "E". What kind of fuse is that ? I believe it's labeled "Remote"! Maybe it's back to front and reads 3 amps. 😉
2s9vzy
I think the "E" is a "3". Digital display numbers and letters leave a lot to be desired sometimes.
Gene
