Bob B.
- May 21, 2021
- C-26
- Blue Honu
My trailer is an EZloader made for a 28 Cutwater ( 2012 ). It is an 11k dual axle trailer converted to carry my 25 SC. The scales tell me my boat and gear run between 9800K to 10600K depending on how much fuel or water and gear I wind up having left on board ... usually tow around 10, 000 lbs.
EZLoader says as long as I am under 11000 I should not have any worries relative to load bearing.
However ... I have had to replace two fender support brackets ( aluminum post between the wheels supporting fender and mounting to frame ) and have a third one that has a weld break and needs replacing before my next trip. I have also had to replace 2 disc brake flanges ( connect the brakes to the axles ).
I do not know if my torsion axles are worn out or I need a 3rd axle but I fear I have too much travel in my axles and the fender gets bumped under the hull and that pressure breaks the bracket - also if this is happening perhaps the disc brake, when grabbing the rotor, flexes the caliper bracket to the point of breaking (cracking) if the torsion axle has too much travel?
I am only guessing as to why this is happening but I can not continue to keep fixing these issues - happens almost every trip. I really need some assistance in trying to figure out the cause of this problem. EZloader has been great with getting me replacement parts but less than great in offering a solution. I can say my bearings and tires are cool when traveling.
Hope someone out there has some ideas for me.
Bob.
Bob.
