On Solitude, we used the Honda Generator to run the air conditioning overnight. Since we were using her on Lake Mead and Mohave when night time temperatures did not drop below 90 degrees it was necessary. I did find that you could not run the Honda on it economy mode as it would shut down on the power up of the AC. The only drawback of using this generator to run AC was, it would burn a tank of fuel (1 qt) in four hours. That meant getting up twice overnight to refill the tank. And, I will tell you, DO NOT let it run out of fuel.... There is no way to prime the carburetor other than the pull start. Not something you want to do at 2 in the morning when it is 90+ degrees outside.
One thing I would note here. We were the only boat in the anchorage so running the generator overnight did not disturb others. Maureen can sleep through a hurricane and I can sleep with a "constant" noise so it did not bother us. Maureen was always amazed that I woke up just before the tank ran dry to refill it without the aid of an alarm.
We placed the generator on the swim platform and ran a cord to the shore power inlet. While running the AC, we could not run the battery charger or water heater. The AC demanded all of the power. We used solar panels during the day to take care of the battery needs. For hot water, we used solar showers (still do, great way to conserve water in your tanks).
On Karma, we went with the Mase Generator. We used it to run the reverse cycle of the AC to provide heat when on the hook as we had no Diesel Heater.
On Destiny we have chosen not to get a generator. Our plan today is, if we find our power needs require additional charging capabilities, we will mount solar panels on the pilot house roof. Along with that, we have room to add additional house batteries to increase our amp hours. In the event we still find we need "some" additional power, we would purchase a Honda Generator. Right now though, we do not think that is going to be necessary.
