Bosn Mate
- Dec 23, 2015
- R-29 S
- FMLT2912I718
- Tingira
Good Afternoon:
I just completed periodic maintenance on the generator which included changing the impeller.
I would appreciate any insight on the following issues:
1. When I first attempt to start the generator, it will not start until I manually move the arm attached to the run solenoid.
2. There are three drilled holes on the body of the impeller raw water pump that drip raw water when the generator is on. I don't remember ever seeing this.
3. The water pump drive belt is slightly over the edge of the top pulley despite me tightening the tension. I don't see any way to adjust so that the belt runs in the center of the pulley.
Thanks much!
Mike
Thanks much!
Mike
