Nmea Backbone
Jfrano
C-30 CB
June Sea
Where on a RT29 can I find the NMEA backbone, I’m trying to add a Yacht Devices Wifi Gateway.
Behind the helm, accessible from the head. Look for a bunch of tee fittings chained together.
My 29 has it located behind the back cave panel. Same place you access hot water tank.
Sent from my Pixel 6 Pro using Tapatalk
My 2018 R29 it is forward of the cave bulkhead - Like Dexmot. It is along the starboard wall. Picture it "under" the throttle quadrant.
I hope that helps.
Rocky
I hope that helps.
Rocky
Same in our 2022. The other end is available under our CB dash. There is also room in the available fuse box. Would only recommend this for items that can be mounted in an outdoor environment.
