No Engine hot water or Heat?
Sine Wave
C-248 C
Sine Wave
Recently I found that we no longer had engine hot water heat or heat coming from the heater. After checking to find a valve closed or something like that I found that I had pulled the heater located at the foot of the Captain out when working on the water pump and when I re-installed it I turned it 180 degrees causing the hoses to crimp. Easy fix....Turned the heater around and re-install. Hope this helps someone else.
Sine Wave
Ft. Myers, FL
