No TV reception on 1 of 2 TV’s.
Mastercraft
R-29 S
Does anybody know why I have no tv reception.
2017 R29
Salon TV reception works fine.
No Tv reception on berth. It has recently worked.
Co-ax antenna is plugged in.
Both TV’s are scanned for local channels
Berth just says “no signal” on blue screen.
I am hesitate to rescan for stations since I might get nothing
If both TV’s are on channel 5-1, salon works, berth doesn’t
Hello,
I would make sure you are set to US channels and what I would also make sure is to have the coax connection behind the TV (berth) well connected. Maybe you also want to switch the connections at the splitter just to make sure you don't have an issue here either if the above doesn't work out.
Thank you,
also had an issue where the cable going into the splitter had too much pressure on it and it snapped the connector right off the circuit boatd inside the little box. Took it apart, resoldered and tv is back in business.
Stuart
