Oil pressure a little high??
SteveCW30CB
C-30 CB
My oil pressure is running about 67 psi when the engine temp is 185 and rpm is 3100. This is higher than the specification (I.e., 60 psi), but is it anything to worry about?
Steve
C 30 CB (435 D6)
Hi Steve,
Volvo Penta’s own manuals don’t give a single exact oil‑pressure number, but they do define what’s considered normal and when the ECU starts to worry.
What Volvo says about normal oil pressure:
- The D4/D6 fault‑tracing section states that normal oil pressure at hot idle is 200–300 kPa (29–43.5 psi). If it drops below the engine‑protection threshold, you get a low‑pressure alarm.
- In the VODIA logging table, “Engine oil pressure” is defined with a working range 0–879 kPa (0–127.5 psi) and a normal sensor value up to 700 kPa (≈101.5 psi).
- The D4/D6 operator’s manual gives typical hot‑engine values as about 125 kPa (18 psi) at idle and ≈440 kPa (64 psi) at full speed for D4/D6 engines, which matches what’s in my checklist for the D6‑435.
- Alarm thresholds are set so that anything like <40 psi at cruise or >120 psi is abnormal and needs investigation
Hope it helps. Like Mastercraft said, go enjoy your boat!!!
Best,
Alex
