Rocky Lou
- Aug 2, 2019
- C-302 C
- Sea Suite
I have questions about the engine pod. I’ve read most of the threads on Tugnuts, but, don't see the answers I'm looking for.
My 2019 C302 has a drain in the center of the pod and, when I’m trolling in the ocean and water runs across the pod, the bilge pump is pumping often. The pump is not operating when I’m in the dock nor when running at higher speeds. When I remove one of the pie hole covers, I see only a small amount of water in the pod. In all, things seem to be working normally.
However, I am still wondering:
- Why is there a drain at all? My Grady Whites had sealed Grady Drives that did not take on any water. That would be desirable since any water adds weight to a hull that is already extremely stern heavy.
- Are there any factory bulletins or best practices that I should be aware of? Kindly advise.
