overhead helm wires
none
C-288 C
DANCA
I'm installing a fold down TV DVD player under the overhead shelves above the helm and also would like to install
a couple of window fog remover fans. My problem is the wiring I know I can rob power from the search light is there
another option has anyone ever run additional wires up there????? if so please let me know.
Jens Jensen BC Canada
I would not rob power from anything. If you look in the cabinet above the hanging locker in the master stateroom, you will find a fuse panel. It is the one that has those flat fuses in it. You will have lots of spare places in that panel to add a tv or your fans. Each idem needs it's own fuse. Find out what your device requires and then wire to that available circuit and put the proper fuse for that device in the circuit you create.
Running the wires will be a bit more tricky. You can feel wires behind the liner just to the right of the far right forward window in front of the helm. You will need to get creative and figure out a clean way to run through their. I will look closer at mine tomorrow and let you know if I find a easy way to do that.
If you need I will take pics of what I am talking about and send them to you.
Good luck!
Stuart....Spirit of Gratitude R-29
Hi Jens, We've had good luck running wires under the deck liner carpet just aft of the starboard helm window. You will also need an antennae coax to your TV. Call me at the factory 360-794-7430 and we can talk about it more in depth.
Howard
Hi
I haven't run any extra wires on my tug.. yet :roll: .. but this is something that I feel is important to note when running wires for any circuit.
Always ensure that the wire size you select will be able to carry the load of the device it attaches too. Not only should wire diamater (guage) be considered, but the length must be accounted also.
Something else to remember as well, the fuse is to protect the wires, not the device. The wires are more likely to overheat and cause a fire then the device is.
I'm not a member of this forum: http://forums.nasioc.com/forums/showthread.php?t=1680307, but the poster in that forum has some really good infomation, taken directly from AC43.1B Acceptable Methods and Practices Manuel published by the FAA. It has a chart that will assist you in selecting the proper wire size. You should know the voltage, length of the wire run, and the amperage of the device you are powering. I would use Curve 1 as the lowest for the discribed application as the wires will need to be run through an enclosed area with other wires.
As an example, lets say you have a continious load such as your fans and they will draw 10 amps. The wire will be 20 feet long. Use 14 volts as the voltage since the alternator should produce that amount (most likely 14.4v). On the chart, follow down the 14 volt column until you find 20, then follow across until you intersect the 10 amp diagnal line. Where the two intersect drop straight down and you will find that you need a minimum wire size of roughly 13. Round up to the next larger wiresize and select 12 guage wire. The larger the gauge number is, the smaller the wire, until you reach 1/0 (pronounced one ought).
I hope this helps and feel free to ask questions anytime.
Good luck with your additions,
Bri
