BB marine
- Feb 1, 2016
- C-26
- Non-Fluid Motion Model
- Grady White 208
- PORT-A-GEE
Ed604":25iv4rm6 said:Hello Brian,
I had a quick question for you. When you are using the generator are you plugging the shore power cord into the generator or, are you connecting the generator directly to the battery bank and using the 12v feature of the gen set?
if you are using the 12v feature, do you just use jumper cables or did you splice up some eyes and alligator clips for the cable to connect it? I am thinking that going direct to the bank will get the most efficient use of the gen set?
I have purchased a larger panel and am going to test it out to see how it goes on my trip. I am also going to bring the gen set as I do have the room. I just hope not to have to use it!
thanks,
Ed604
Most inverter type generators 12V source is less than 10 amps. Some 8amps or 6amps not enough to really do anything when charging a 200 AH bank at 50% charge.
I use a 10' cord 8/3 AWG round boat cable. 30amp plug on one side 20amp plug other side. I have a ground to neutral adapter plugged into the generator when I use it on the boat. Start generator, turn main panel breaker on then turn battery charger on. The key to charging the batteries is to try to do a full cycle ( full charge after depleting the charge) The issue with the standard charger on the Rangers and Cutwaters C26, C28, R25, R27 and maybe the larger Fluid Motion boats. The factory installed charger was only 20 amps. This is not big enough to charge the batteries when at 50% discharge. The charger max output is 20 amps charging three banks. Installing a larger charger will reduce the run time and charge the batteries to or close to a full charge in a shorter period of time. Maintaining the batteries for days without a full charge will shorten the life cycle. Ask me how I know! When I had the Cutwater I never had a dead battery but I never had a battery at full charge when we stayed at anchor for a few days. The key to good lead acid battery maintenance when staying on the hook for days in my opinion is Solar, Solar, Solar and a back up way to charge the batteries to a full cycle each day. Next is battery capacity 400 AH minimum (Lead Acid) 600AH is better. Thats a lot of battery in a small boat. If I had my C26 now it would have Lithium batteries and a full aluminum frame covering the cockpit. The frame would be covered with Sunbrella and above the Sunbrella covering would be solar panels a minimum of 400 Watt preferably 600 Watt if I could get them to fit.
