If I may offer a suggestion, before you run the genny, remove the spark plug and coat the threads with anti-sieze. Since the cylinder head is aluminum and the spark plug is steel, and it's in a salt water environment, it's not a question of if, but when it's going to corrode.joelcop":3vn8e10s said:Well, I couldn't resist the prime day deal on a 2200 watt Westinghouse inverter generator. (Sorry Harbor Freight).
Does anyone have any pictures of how they secured it to the swim platform? Or should I drill holes and just mount a few padeyes?
Any ideas on how to make it a little more weatherproof for when it's exposed back there and an unexpected shower comes along?
Best way to drain the fuel tank/carburetor so gas doesn't sit in the carb after running?
KKRCRACE":3of5kqvt said:I made an aluminum tray with 2 inch sides and three inch legs to give me 5 inches of safety from backwash while the Honda generator is on the swim platform. I also purchased a set of the generator feet from Honda to put on the tray to reduce vibrations. When not running the generator I keep the Honda cover on the generator to keep the salt air off. I also spray the inside of the generator with a CRC product to help stop corrosion. The generator is secured to the swim platform with two SS inch worms that are through bolted into the wall just above the base of the platform and a small SS ratchet strap. I run it and leave it there as long as traveling in calm seas. I also made an aluminum exhaust pipe that uses an SS hose clamp that lets me direct the exhaust away from the boat. This works very well for us.
KKRCRACE
