Thollis2
- Sep 10, 2021
- R-25 SC
- Corvus II
After 4 years of owning this 2014 R-25 that we moved to Puget Sound I took a close look at all the components in the starboard lazarette. The hot water tank had a minor amount of rust in one corner and the autopilot pump had corrosion on the fittings. I keep wet dock lines, the deck brush, crap pot floats and other random stuff here. Should I be rinsing off the salt water and letting everything dry out before I stow it? Is minor corrosion preventable on a boat that's kept in covered moorage in salt water all year?
I've cleaned off off the corrosion and put on a protective grease barrier.
Looking for advice on better housekeeping going forward.
