BB marine
- Feb 1, 2016
- C-26
- Non-Fluid Motion Model
- Grady White 208
- PORT-A-GEE
Last week I changed both the bulkhead mounted Racor filter and the engine mounted Volvo filter. The bulkhead filter was no problem .I did install a Racor drain valve instead of drain plug, bottom of the bowl so I can check for water easier then removing the drain plug. (less mess) . The engine mounted filter , not so easy. I had to remove the filter housing and put it in a vise to remove the filter . In doing this the fuel lines, and two filters are completely dry. Manual says do not fill filters before installing them. Use the pump primer button to prime system. Push and hold for 5 seconds. I want to check for leaks at fuel lines and fuel filters now. My boat is still in storage. I can not run the engine. Will I do damage to the pump running it for a period of time to fill the system with fuel and check for leaks . I don't think 5 seconds is going to fill two filters and the fuel lines. I don't want to deal with a fuel leak if I have one. At the launch ramp. Any information on this subject will be appreciated.
Brian Brown
26 Cutwater
PORT-A-GEE
Brian Brown
26 Cutwater
PORT-A-GEE
