Irish Mist
- Apr 25, 2012
- Orillia Ontario
- R-29 Classic
- FMLT2922K011
- Irish Mist
One of the issues with overloading is in the event of a power failure at night or during the day while away for a while. If you have heat on and the water heater , if there is a power failure the inverter automatically comes on and does what it can to keep up... This could be happening with out any one knowing if the power is restored before you return or wake up . This can be overloading the inverter unintentionally .. I have also been at marinias where they have a 30 amp receptical and only 20 amp breakers... Using your normal loads can result in blowing the breaker and the inverter takes over.. Because it is an instant transfer it does not get the start up loads and will run a fair bit of load. In my case two heaters and the charger.
I'm thinking this could be the cause of some failures that you may not be aware of.
I will change to the pure sine once this one fails again .
