TortugaR31
- Jul 31, 2020
- C-302 SC
- Tortuga
Our 2016 R31CB has the ProMariner 2500QS charger / inverter. With the boat plugged in to 30amp shore power, AC1 turned on and the red remote panel switch set to Charger Mode, the green Inverter light on the actual charger illuminates and then after a second the yellow Charging light and green Shore Power light on either side of the inverter light illuminate and the Inverter light shuts off. After a few more seconds, a click is heard, the lights on the charger all go out, and a high pitched beep sounds continuously. Any thoughts as to what is happening? The owner's manual isn't much help, and I have called the factory multiple times and there is no answer.
