tkaustin
- Mar 11, 2014
- C-26
- 2501B010
- coming soon to a stern
2011 RT 25SC. The case of my Promariner 1500QS has shown rust for a couple years, and recently the entire unit has become an open circuit. It won't do anything. Removed it and opened the case. External examination showed the two circuit breaker reset buttons corroded sufficiently that they don't move. Internal examination showed heavy rust on just about everything except the electronics. Most disturbing is the veritable explosion of the laminations of the large transformer. This thing is toast; I won't spend any resources to resurrect it. Not only am I disappointed in it failing, but even more so, disappointed at the extraordinary rust inside. Note that everything else in the "electrical room", under the step on the port side of the cockpit is gorgeous. All other wiring is clean and secure.
Why would a Promariner not be prepared to exist in this environment as well as the rest of the electrical system?
Next question is the problem of whether to replace the unit with another Promariner. It's hard to do, given the problems I see here. Amazon led me to SUNGOLDPOWER 2000w Peak 6000w Pure Sine Wave. It's cheaper and seems comparable in terms of performance, including moving up to a true sine wave. A 2000W PureSine from Promariner gets near $900, whereas this one is $600.
Aside from the rant, I'm asking if any others out there have experience with electrical boxes other than ProMariner.
Thanks.
Pictures here. Should be open to anyone with this link. https://goo.gl/photos/mcTT4HkiYKsmniuHA
Thanks.
