nzfisher
- Jan 26, 2009
- C-26
- Swims with Tuna
I had the prop nut zinc falling off on my R25sc in earlier years. Since then I "fit" the zinc to the prop nut by putting a light coat of thin white paint to see where it was "touching" the nut assembly. I found that the nut was hitting the cotter pin excessively which caused it to not "seat" properly on the nut. Since then I have formed the cotter pin to no longer hit the zinc and found a larger thinner stainless washer(s) that provides for a compression thrust fit that provides some extra spring thrust against the zinc as it wears. Since then I no longer lose prop zincs. I also set the prop nut with a bronze hammer and file flat the mating surfaces to get as much contact as I can between them. How tight to torque the bolt remains an open question. My current birth is pretty good for stray current and I also put zincs on the rudder. Some combination of the above has seemed to make a difference in lost zincs. I replace all zincs when I pull the boat and the boat is only in the water 5-6 months.
