knotflying
- Jul 25, 2010
- C-28
- FMLT2731J011
- Non-Fluid Motion Model
Your's is somewhat different than mine, but same principal. It does look like burned material. Just to review a few things. I assume you used 3 pieces of material with a bias cut on each piece to cause an overlapping joint and you staggered the joints at about 12, 4 and 8 o'clock? Did you pack each piece in tight before inserting the other? Did you keep the initial tightening somewhat loose ( letting more water through) until the packing wore in and seated properly. This requires running a bit and slowly tightening over time until drip comes at 20 second intervals. Are you getting water flow from the hose going into the barbed fitting on the shaft? I assume you are getting flow out of the barbed fitting when the hose is removed? Your temperature at the fitting should be about 10 to 15 degrees higher than water temperature. Drip should be once every 20 seconds when shaft it turning. For safety sake, I would do a replacement out of the water. It will work fine in the water if all is okay, but I wouldn't chance it.
