Propane stove cover
CartersRanger
R-31 S
Going Places
Hello!
I have a 2 burner propane stove and oven and would love to get a cover for it when not it use. I found a picture of a 2015 tug with the cover I’m looking for. I couldn’t find that the company actually makes it for the stove so I’m assuming it’s after market. Any help in locating one would be appreciated. Two pics. One without cover is my stove. Second one is the stove with the cover I want. Thanks in advance
I found a bamboo cutting board that was close in size and trimmed it down in the shop to fit. If you do this, or even if you buy one, be sure to cutout a slot above the oven vent at the back edge.
Second Curt’s suggestion. I bought a 15.5”x11” cherry cutting board from Home Depot for $25. A bit smaller than full stovetop coverage but it works fine for us.
Hello!
I'm with the other two folks. I happened to have a Corian cutting board that fit my RV's stove perfectly. I brought it on board the boat, made some adjustments by gluing on rubber feet that make it fit properly without sliding off, and now use that. It's great for extra counter space. I do remove it from the stove completely when I use the oven, though. It doesn't block anything, but I think heat from the oven might damage it.
Bonus is that I can take it out in the aft cockpit or swim platform and use it to clean fish without having to bring them into the boat.
Cutting board. Found one the size of stovetop. Cut two slots for the fiddle rail at the rear. Slides in, stays put.
On our two burner is a Plastic 3/8" cutting board. Works well, but found that when using the oven remove it, is now slightly warped. Easy to make one, or take measurement to a Plastic shop. Need to have indents on the front side corners to clear the front rail corners where the pan holders mount.
