Proper Use of Honda 2000 Generator
uppy22
Sea Ray 270 Sundancer
Saleboat
This is a pretty basic question, but I'd like to hear what others think...what is the proper way to hook up and use a Honda 2000 generator. I've got my method, but I've read too much and am now doubting/curious.
All I do is plug it into the shore power connection with an adapter cable I built.
No wiring changes to make on the boat.
If you get the one with the two different outlets in front , you will find that the locking shore power plug can be plugged directly to the generator . If you have the other "companion " generator , you will need to get an adapter plug .
I set mine up with the exhaust pointing out the open swim step door . The polarity light on your panel will indicate a problem for which there is a fix , but I'm told it's no issue and can be ignored . The only system on the boat that the generator would probably not run is air conditioning. I have run everything else including the hot water heater with no problem .
Ditto Workingdogs. Interestingly I have only used my Honda 3 times over 3-1/2 years and that was to exercise it. I have now removed it from the boat and I am waiting to see how many times I wish I had it. :lol:
I've been wondering how we could do the same thing with our Honda 2000i. But we have the Smartplug shore power system. Anyone with a Smartplug who has devised a solution? Maybe an extension like this on dockside end of the Smartplug cord?
what is the description of this adapter plug. Reading your post I realized thats how I can plug n my R25 when I tow it home for work. Is it a 30 amp or 50 amp plug.
I made one like that with the SmartPlug end on it. Very handy when plugging in the boat at home, using the Honda 2000i, or when 15 amp is all that is available.
Jim
Perfect, Jim! It avoids an overly long extension cord set up. Tidy and efficient. Did you get one of the regular 30 amp to 15 amp cords (like the one pictured) and then cut off the normal 3-prong boatside connection and add the Smartplug? Or did you make it totally from scratch, adding both ends to a length of shore power cord? Given the cost of the pre-made connectors and the Smartplug, building one from scratch would probably be the most economical option, if it can be done. Great solution either way!
By the way, if you want to go to a campground the 30 amp connection is different. You can buy a 30 amp camping to a 15 amp plug. I then use the 15 amp plug to 30 amp marine and use my regular shore power cord.
Hi Gin,
I bought the pigtail with the 15 amp plug on it. Inexpensive at an electrical supply house. Good heavy gauge wire. The only hard part about wiring the SmartPlug is fitting the yellow cord through the rubber sleeve on the back side of the SmartPlug... a little bit of dish soap makes that easy. The wiring is simple: connect three wires.
This is the adapter you need to connect your 30 amp shore power to 30 amp in an RV park...
http://www.homedepot.com/b/Electrical-E ... 5yc1vZc4ny
Or, if 15 amp is enough for you, the SmartPlug pigtail into a heavy extension cord is adequate.
Happy New Year,
Jim
Gin
I ran in to a couple on east dock this summer who recommended this Portland local dealer for a generator. They said they were also very helpful with setup and accessories. Illbe going after the first of the year.
http://www.cessco.us
Bryce
Bryce, I already have the Honda generator (thankfully, since the inverter went out on my second night of Christmas ships, pulling only 254 watts!). But in case I need anything else like that in the future, the place you linked to is good to know about. Thanks!
Gini
