Pump out holding tank
Fowlnest1
Tug on This
Has anyone had problem with getting nozzle into pump out fitting? Rail blocks it..
Yup - first time I tried to pump out, the marina didn't have a fitting that would fit (and they had at least half a dozen of them for various boats). I paid the guy $20.00 to go to a nearby boat storage facility and borrow their tapered rubber adapter (hold it down TIGHT! 😱 ). As soon as I got home I made up several configurations out of black polypropylene threaded fittings (90, 45, & short straight) to the marine male camlock fitting (get the smaller 1 1/4" MPT, 11.5 tpi size). I thought keeping everything all black was appropriate. 😉 BTW - they almost float - so I added a keychain floatie to each of them (trust me, you want them to float) - now they barely float.
The second lake I went to only had RV gravity fed dump stations. So, as soon as I got home I made up a 3/4" hose, fitting and adapters on both ends (pieced together from replacement parts from Valterra SewerSolutions kits for RVs) to connect the boat's overboard discharge fitting to an RV dump station. I do not use the added water hose hookup feature - it works GREAT (takes about 3 minutes to pump out a full tank, uphill!) I store everything in the propane locker.
However, I'm still not thrilled with the through hull fitting connection. So, I plan to add another Jabasco Y-valve and use a quick disconnect to the sewer hose I already have (I have everything I need, except the time to install).
I won't be hauling my crap back home again.
BTW - I take no credit for designing any of this. I got all these ideas from others on this forum (I'd give them credit here, but I don't remember who they all are). SEARCH is your friend. Good luck.
Todd
Thank you..Maybe the pump out configuration is different in the Northwest.I.E origin of boat..
Does anyone know if this same problem exists on the R-23? :?: If it does I might want to build the adapter as other's have done.
Thanks!!
We have not had problems pumping out our R23.
Concur with Brian B. I made the adapter as he suggests. Works great.
