johnniethek
- Jan 23, 2009
- C-30 S
- FMLT29211617
- Salish Searcher
Greetings one and all,
I need some technical advice on what might be wrong with the 30 hp Yanmar that is in my 2009 R-21 EC. It has about 1,000 hours on it.
About two months ago, I was trolling in Hood Canal, and the engine rattled and shook, and then just up and died. I would let it rest for a few minutes, it started right up, and then died again after 2-3 minutes. This happened several times until I finally got towed into Pleasant Harbor Marina. I took it to Tacoma Diesel where, at a cost of $650, they went over the whole engine, including adjusting the valves, changed filters, discovered the source of the loud noise coming from under the engine box (one of the bolts that anchored the engine onto the hull had come out), etc., etc. But Tacoma Diesel isn't located on the water, so they couldn't monitor its performance while it was under way.
When I next used the boat off Sekiu last week, it operated great for about two hour (trolling) when it did the same thing. It just up and died. It's not like the engine wouldn't start. Or that it was missing. It just up and died. The oil and battery lights were on when it died, but there was plenty of oil in the boat and it had new batteries. I left the engine off for about five minutes, started it right up again, and it died after about 2-3 minutes. This happened several times before we switched to the kicker motor and came back in.
After checking everything, including the thermostat and fuel pump, we let it sit overnight. It started right up the next day, and we went fishing for three hours until it died again just like it did the previous day and in Hood Canal. Once again, we had to come back to the marina using the kicker motor.
One of the things I discovered since then was that the gas fuel cap was coming unscrewed and popped up during operation. Could the broken fuel cap, somehow, have allowed air to get into the fuel line causing a vapor lock? That might explain why the engine runs fine for a few hours but then shuts down. I bought a new fuel cap/unit that is being installed on the boat today. I think the broken cap may have also allowed water to get into the fuel tank because it no longer stays screwed shut like it used to. I had the tank drained and cleaned, and added new diesel. Could the water that previously had been in the fuel contribute to the problem I am having now? I am (obviously) not a mechanic, but one of my buddies says the water that previously was in the tank may have caused a problem with the fuel injectors...does that seem plausible? If so, what's the remedy?
Thanks, in advance, for any help you can provide.
JtheK
JtheK
