R-21 EC Winterization In Water Year Round
wilsonballew
C-24 C SE
Gilgamesh
Hello All - I am taking delivery of a 2016 R-21 EC tomorrow with the Volvo engine. We will be keeping the boat in the water year round at our slip in Baltimore Inner Harbor area. I would like to get some advice on the winterization process required for the tug, as this is the first time we are leaving a boat in the water year round. There certainly could be times when the boat might be taken out on the water over the Winter. Any advice would be appreciated. I would especially appreciate hearing from folks in the Chesapeake Bay area that are familiar with local weather in this area and who also keep their boat in the water all year.
Thanks! Tom
Thanks much Sheepdog...I will participate in the presentation. We had been looking for an R-21 EC for some time and felt the market was a bit overpriced in the current Covid Boat Madness Syndrome [CBMS] market, but ran across the 2016 in Florida with 85 hours and original owner. Price was fantastic and survey was near perfect, so really looking forward to enjoying the boat. 😀
I’m in the PNW and use my boat year round. I do winterize the engine in between uses as it only takes a couple minutes. I winterize the freshwater and holding tank and don’t use them at all during the winter. I run a small heater in the cabin, which would probably keep the freshwater and holding tank system from freezing but it’s nice not to worry about it. Give me a call if you’d like to talk about the engine winterization process. I have the Volvo, too. 425-344-1727.
For the engine:
You need about 1-2 gallons of pink (rv/marine) antifreeze. It's really like 1.25 gallons I think. Easiest with two people.
1) Close seacock in front of the engine box! You access it via the access panel between the engine and cabin.
2) Open engine cover
3) Locate the sea strainer. It should be mounted on the panel between your engine and batteries
4) Unscrew the lid on the strainer (might as well clean it if there's any gunk in there). You'll notice it's full of water.
5) If you have another person, have them start the engine and slowly pour antifreeze into the the sea strainer as the water draws out.
6) If you have a hand, have the other person look out over exhaust discharge (starboard side) and tell you when they see solid pink PG antifreeze flowing out.
7) Kill the engine using the engine stop level mounted on the front starboard side of the engine (it should say "stop" with an arrow on it).
8) Replace sea strainer cap and close engine hatch.
For the holding tank:
1) Pump the tank if full
2) Dump about a gallon of antifreeze in the toilet
3) Pump the toilet until you see pink PG antifreeze enter the holding tank.
For freshwater tank:
1) Turn on freshwater pump at helm station
2) turn on sink and drain tank. Turn off sink when empty.
3) Add 1 gallon of pink PG antifreeze through the deck fill.
4) Turn on sink until you see pink PG antifreeze flowing out.
5) Turn off sink, turn off pump at helm station
That's it!
wilsonballew - We bought our 2015 this past July. She had 15 hours on the recall replaced motor and had lived her entire life on a large lake in New Hampshire, she is in pristine condition. She now has 75 hours on her and I'm hoping for a few more before the long winter here in Maine. Couldn't be happier with the Island Girl. Get ready to be approached by folks at ramps, marinas, parking lots etc... the R-21's draw a lot of attention! Best of luck with yours!
tylerformeveret - Thanks for this information! This is what I had planned but it's great to get confirmation. Glad the motor winterization is so easy, as the Island Girl will be kept in a garage not shrink wrapped, so I'm hoping to sneak in a few days in the winter if possible!
Thank you so much Tyler...seems like a snap and I'm with you, keep the holding tank and fresh water winterized but can easily redo the engine if I decide to taker her out. We had a very mild winter last year and don't know if that will repeat again this year; as winter goes here in the mid-atlantic it's never really that bad and with the enclosed pilot house and heat, a romp around the water during the winter is totally doable.
As coincidence would have it, there is a Ranger Tug (I think an R23] two slips down from me and directly across is a Cutwater 26 or 27. These boats just recently showed up and I have not yet run into the owners, but my Ranger makes three at our marina.
I read a lot about best way to winterize is not to run it through the fresh water tank but to pull the hose from tank (After you run sinks dry) and take that inlet hose and place (I have a t I placed in with coil of hose and valve) in about 3 to 4 gallons of anti-freeze till every faucet and toilet pees pink.
I then put a few gallons though empty toilet and down shower pump and also close all seacocks for A/C and FW wash down and be sure A/C and wash down also release pink.
Be sure to drain H20 heater first
Before I converted from RV to Boat I never used Antifreeze I had a great compressor and used air and in NH never ever had an issue I had fittings I made it was a breeze. I think with some hose and skill someone could make a antifreeze hose system that all goes back to a tank and small pump and make this process a bit easier.
Good luck
Wilsonballew, good luck and congratulations on your delivery tomorrow. Last winter was our first so I used a variety of sources (especially TugNuts) to pull together a comprehensive checklist that combines winterization and maintenance. You can find it in the forum index under Ranger Factory Technical Bulletins, titled Ranger 21EC Winterization.
