R-23 Port Cockpit Locker not draining
bradpeek
FMLT2305E718
Gooner
Morning,
We washed our 23 yesterday, but didn't clean the deck drains first (won't do that again!) so water pooled and did drain into both lockers and cockpit bilge. The port side didn't drain into the center bilge though. We did find a 1" hole in the front of the locker bilge, assuming that might be the drain into the center bilge and the initial 6" or so didn't have any blockage. We're returning tomorrow w/ a little snake to flush down the hole.
But, is there another drain under the house/starter battery banks? Before disconnecting and removing them to check, it'd be great to know there's something under there!
Cheers!
Brad
MV Gooner
Ranger R23
Yes, there is a drain below the batteries. Take your cable and start from the center lazarette to clear it. There is a bend, so it takes a bit to get a cable through.
I just cleared my blocked drain thru-hole to the port side laz and it started flowing nicely. Of course a bunch of crud flowed out. Very satisfying!
The other drain hole that Bradpeek mentioned, center laz but forward of the raw water valve. What is the source that connects to that?
