Subject: R-27/OB F300 back-flushing and flying snake-like hose
This subject was not meant to be a 'bait switch' :lol:
Yesterday I ran my engine for back flushing and had the hose attached to the back flush receptacle and had proceeded to run the water from the hose's shore faucet. All went well with seeing the engine peeing so then started chatting with some dock friends.
I normally allow the back flush to run for 5 to 10 mins while I'm doing other things.
This time I was suddenly alerted to the hose end attached to the engine flying up into air, whacking everything within its reach, spraying water everywhere including me and friends and the boat.... what the heck... 😱 :x
I raced over to the engine and secured the flying snake-like hose end only to discover the barbed plastic tube that fits into the rubber hose of the engine's back flush had pushed out allowing the hose end to fly about uncontrollably.
Upon inspection I noted the barbed end is secured to the inside of the engine's rubber tube with nothing more than a nylon zip tie. Obviously, the water pressure or the back pressure from inside the engine was sufficient to force the barbed tube to be ejected and that the nylon zip tie simply was insufficient for securing the barbed tube.
I've back flushed my engine many times and this was a 'first'.
Thank goodness the barbed tube was secured by the hose end attachment so it was not flung to the deep dark waters.
I will be replacing this nylon zip tie with double clamps for sure to avoid this problem from occurring. I consider it to be a safety issue as an adult or a small child could be harmed with the forceful whipping snaking hose end action with its metal end, and could with the force take an eye out or smash teeth in easily.
I will be sending feedback to Yamaha about this issue as well.
