Rwarner
- Jun 30, 2018
- C-30 S
- FMLT2916J718
- FODUCK
New 2018 R-29S and could use some help with an electrical problem. Low voltage on battery bank 1 and sometimes 2. All batteries after being on shore power show 13.5 volts (after a night). First question for the 12 volt AGM batteries what is the correct voltage they should be while charging? I have read different answers, most stating something above 14. I have used the battery parallel switch to “reset” the charging relays when the voltage has dropped below 10.8. After weeks of trying different cobinations of shutting off things that use power and using different power sources. I can honestly say the only thing that appears to charge the batteries well is the solar panel. Bank 1 according to the manual is the house set and bank 2 is the engine. On the voltage gauge I get a very different reading on bank 2 vs the Volvo engine display with the ignition ON but engine OFF. After stating the engine the Volvo guage will show approx 14.2 volts while the needle guage shows 11.5 at best. Running the gernator seems to help prolong bank 1 from dropping to 10.5 volts but it will happen while underway. Shore power will slowly bring everything back up. However if I use most of the interior LED lights I am right back down. Quite frankly my head is spinning and I need to get pointed back in the right direction. Thoughts?
