OdyseaII
- Mar 11, 2022
- R-31 CB
- FMLT31081819
- Odysea II
The forward Dometic AC on our 2019 R31 CB switches to heat after running for a few hours for no reason I can understand.
With an outside temperature of 85+ here in Texas we run both ACs while on the boat with the thermostat set at 74. On two occasions the front AC has switched to heat after running the air about 6+ hours.
I was told this could be to make sure the unit is not freezing but the back AC does not do this and I am not convinced this is normal.
It seems to clear some time but I am wondering if this is normal or I have an issue.
I am wondering if maybe there is a problem with the temperatur sensor that feeds the unit?
Another thought is to re-program the control so the heat does not come one.
Any help or ideas would be greatly appreciated.
Thank you,
Keith
Odysea II
R-31 CB
Thank you,
Keith
Odysea II
R-31 CB
