R21 Classic Wet Keel?
jpayne_R21
R-21
I noticed when replacing the bilge pump below the shaft in the bilge area that the mounting holes are drilled into the keel that appears to be hollow and I have to assume has some water in it. Does anyone know how the keel is constructed on these boats and if I should be worried if water is in the keel?? I have a 1994 Classic.
Jim
I don't think there should be any water there.. can you post pictures?
The boat has a "box" keel, about six inches wide. Water normally leaks slowly through the stuffing box on the propeller shaft. It is not adjusted properly if it does not. The bilge pump can't pump down to a completely dry surface. It leaves a fraction of an inch of water that can slosh around in there. A small amount of water is normal.
Larry
