Todd Tugnut":1c7bzmft said:
Thanks for the info! My boat names have been Red Dog, Lucky Dog, and now Salty Dog. I’m looking for a 31CB that I will call Sea Dog. Somehow, I’m going to get those gauges on my Garmin.
I did some brief searching for you. In order for it to work you have to get the instrumentation data off the Yanmar engine. This means the engine itself must support it. It does appear that Yanmar engines do offer this, but alas, I don't own a R21, and I know little about the specific engine you have, what year it was built, the exact model, to be able to find out if it's got the electronics already on it.
Here's an example of what I'm talking about. On my last boat I had a Mercruiser 5.0L MPI engine. It was 2006. Mercury had instrumentation in the engine (called Smartcraft), but I had no gauge, no way to see it, no way to interface it with my Garmin chart plotter. In 2009, Mercury came out with what they call a MercMonitor.
https://www.mercurymarine.com/en/us/gauges-and-controls/gauges-displays/mercmonitor/
The MercMonitor replaced one of the gauges on my dash (I swapped it out for the speedometer). Now I could see the engine data on a gauge. The gauge is proprietary to Mercury and required that engine have Smartcraft (Mercury's proprietary engine monitoring electronics). On the back of the MercMonitor gauge was connectivity options for NMEA 2k and NMEA 0183. The install of the Mercmonitor was super simple. Plug in the cable (quick disconnects on the engine and MercMonitor side, route the cable from the helm to the engine).
Now, this was over 10 years ago, technology has changed, but the concept hasn't changed. What I was reading in a quick search of the Yanmar, it sounds nearly identical in what you're looking for. You need to first find out does your Yanmar have the electronics on it that keeps track of engine data. Then what does Yanmar offer to get that data off the engine. In today's standards, you want NMEA 2000 (N2k) handoff (which is the newer improved version of NMEA 0183).
NEMA 2000 is basically a network that connects things together. Engine, radio, chart plotter, AIS... everything can talk to everything once connected to the N2k bus.
