ohioan55
- Aug 25, 2015
- R-23 (Outboard)
- FMLT2314C424
- Jersey Girl
I've installed a second bilge pump and wiring in the bilge void forward of the engine. I ran into a snag routing the discharge hose. I had intended to route it up to under the sink and splice it into the sink discharge. Problem is that there is no fairly direct route to the sink from that void as the space between the cockpit pan and hull will not accommodate a 3/4" hose to fit (or a 5/8"). I can easily route the hose aft (and have) under the engine into that area aft or the engine where there is space. I have 3 choices for discharge to finish the project and this is where I am seeking others opinions. One is to splice into the primary bilge pump discharge (easy, but the issue with this choice is obvious). Two, make a turn and route the hose forward along the port side of the hull where it will fit and splice into the sink discharge as originally planned (meaning about 20' of discharge hose). Or three, add another discharge on the port side under the cup holder (another hull penetration). Two pumps sharing the same discharge is an easy solution, but the idea of 2 pumps sharing the same discharge could be problematic. The 20' of hose could be a problem as well, but can be done as with ease. And any new hull penetration should always be well thought out and considered essential before drill touches hull, but could be easily done at this point. Ok, the floor is open..
