R21 with power inlet on motor box
daviduphoff
RFB020260581
The Mighty One (Ranger 18)
My battery charger apparently quit working. I figured that it wasn't a bad run as it was the original battery charger from 2009.
The first thing I did was check for 120v power at the charger and there was none. I knew of no fuse between the power inlet and the battery charger so I decided to look at the inlet plug. The hot wire had worked its way loose from the power inlet. I loosened the screw, re-inserted the wire and tightened it back down. All was good again.
I guess that seven years of opening the engine cover over and over again allowed the wire to work loose. If you have a 21 I suggest that you check on the wires on the power inlet if it is a early production tug before it was moved to the back of the cockpit.
