Oregon Trail
- Sep 28, 2012
- C-24 C
- Non-Fluid Motion Model
- Cutwater 28
- Northwest Passage
I have some questions about my "new to me" 2017 R21-ec Northwest edition with the Yanmar engine and Garmin 741xs chart plotter. I am hoping some of you can tell me what is normal or not normal and what you might suggest:
1. The depth does not display on the Garmin. Just dashes.
2. The Yanmar display does not have readings for Temperature or Oil Pressure. I don't know if this is normal or not. Engine hours and Backlight percent do display.
3. The Yanmar display shows battery voltage. I don't know if this is the engine battery or the house battery or if there is a way to show both? It started at 14.0 volts and ended at 12.9 volts a couple of hours later, despite the engine running the entire time. Is this drop normal?
4. I did not find any engine or battery information on the Garmin. Should this info show up somewhere?
Thanks for the support!
Mike
Mike
